Voltage Reference off spec or normal?
Discussion in 'General Electronics Chat' started by illusive, Jan 27, 2016.
  1. illusive
    Jul 9, 2015
    46
    I needed a 2.5V reference voltage and i bought a LM4040BIZ-2.5.It is 2.5V ±0.2% shunt regulator but when i connect it with a series resistor i'm reading about 2.47 volts no mater what load current i set (up to 15mA). Is this within spec or am i doing something wrong?
  2. Lestraveled
    May 19, 2014
    1,957
    1,218
    Without a schematic I can only guess that your meter is off.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Let's see.
    \frac{.030}{2.5}\;=\;0.012 \;= \;1.2%
    Seems like it is out tolerance. When was your meter last calibrated? You do calibrate your instruments at least once a year per ISO-9001 -- right? Did you get the little sticker from the independent lab that did the calibration?
  4. crutschow
    Mar 14, 2008
    13,505
    3,376
    Find another meter to check the voltage.
  5. Lestraveled
    May 19, 2014
    1,957
    1,218
    What kind of meter are you using?
    @crutschow
    That was your 10,001th post, very cool!!
  6. illusive
    Jul 9, 2015
    46
    Yep, i measured it with another multimeter and sure enough - 2.503V
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    So which one do you believe? Are you going to get the first meter professionally calibrated? Is that first meter just a throwaway cheapie that probably can't be calibrated anyway?
    2.5 \times 0.002 = 2.505
    2.503 \le 2.505
    Looks like a winner, and you have a new voltage reference to check meters with.
  8. illusive
    Jul 9, 2015
    46
    It was a six years old 20 dollar one, so i bet it is off.
  9. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Not exactly instrument grade, then. I would label it with ±2.6% sticker just to remind yourself.
  10. Lestraveled
    May 19, 2014
    1,957
    1,218
    Here is EEVblog rant on cheap multimeters.
  11. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Amen. Words to live by. BTW I have a Fluke 77 and a Fluke 117. The Fluke 117 was a perk to my wife, who was a purchasing agent, from a sales rep. I was happy to put it to use.
