voltage reduction
Discussion in 'The Projects Forum' started by LaurenceR, Dec 26, 2014.
  1. LaurenceR
    Feb 7, 2013
    97
    I am looking for the best (simple and effective) way to drop mains voltage down to 24 vdc. My MCU board has circuitry to drop the 24 vdc down to 5 vdc to operate the logic circuits. I was originally using 24vdc as a supply voltage however I now have to use other voltages. My suspicion is a transformer and a zener or a voltage regulator. Any help would be appreciated.
    Thanks,
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Transformer, Bridge Rectifier, and Filter Capacitor gets you 24VDC unregulated. Simple and effective.
  3. crutschow
    Mar 14, 2008
    13,498
    3,374
    You could use a transformer and an LM317 regulator. A shunt zener regulator can dissipate a lot of power.
    Alternately, and more simply, you could use a wallwart with a 24Vdc output.
  4. #12
    Nov 30, 2010
    16,693
    7,334
    Your MCU board will probably drop UP TO 24 volts down to the correct range. Read the instructions and see if it will work on 8V to 10V. That would cause less heat waste.
  5. LaurenceR
    Feb 7, 2013
    97
  6. LaurenceR
    Feb 7, 2013
    97
    Thank you all. All good suggestions. For the sake of discussion using a transformer, rectifier, cap and or regulator sounds very effective. This begs me to ask the question I've been over many times. Do I need to use a center tapped transformer? As I have seen; without the center tap you can't really get full wave rectification of mains voltage. I don't know that the capacitor alone would be enough to smooth out the half wave voltage. I'm sure I opened a can of worms with this question.
    Thanks in advance.
  7. #12
    Nov 30, 2010
    16,693
    7,334
    There are a dozen ways to make, "smooth" DC. Unfortunately, an on-board regulator doesn't need smooth DC. It needs mostly DC that never goes below the minimum feed voltage for the regulator.
    You need to feed a 5V regulator? A "DC" wave that varies from 24 volts peak to about 10 volts in the valleys would work on the regulators I know about.
  8. ronv
    Nov 12, 2008
    3,400
    1,457
  9. Alec_t
    Sep 17, 2013
    5,972
    1,135
    What you have seen is wrong. A rectifier bridge will provide full-wave rectification of a non-centre-tapped transformer output.
  10. LaurenceR
    Feb 7, 2013
    97
    You make a good point about the minimum feed voltage, I suppose a capacitor would keep it above that level easily especially at such low current draws.
    Thanks.
  11. LaurenceR
    Feb 7, 2013
    97
  12. LaurenceR
    Feb 7, 2013
    97
    I already have a voltage regulating circuit on the board that works very well for a 24 vdc supply. I can't remove it so I thought it best not to duplicate it and just bring the high voltage down to the 24 vdc level.
    Thanks.
  13. LaurenceR
    Feb 7, 2013
    97
    This is the can of worms I was talking about. I have tried viewing 110vac passed through a full bridge rectifier with and without a capacitor and all you get is half wave dc. when I view a center tapped transformer I can get full wave on the scope. Am I missing something here?
  14. #12
    Nov 30, 2010
    16,693
    7,334
    sqrt2 C Er(p-p) F = I
    That says: For any current, and any frequency, you can use a capacitor to limit the variations. It is not a matter of, "if". It is a matter of, "how much".
  15. #12
    Nov 30, 2010
    16,693
    7,334
    Yes. You are missing the part about installing a capacitor.
  16. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    It sounds as though you do not need a regulated supply?
    If you use a transformer you will need a 16v-17v AC secondary for 24vdc.
    Max.
  17. LaurenceR
    Feb 7, 2013
    97
    I understand what you are saying. Your equation points how the "how much" however it does take into account when calculating it the frequency "f". When you have full wave rectification the frequency doubles thus reducing the amount of capacitance needed. As you suggest the simplest way may be to rectify the ac, use a capacitor, and feed it to the present circuit.
    Thanks.
  18. LaurenceR
    Feb 7, 2013
    97
  19. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    Yes, or AC = DCV x .707.
    Allow for diode rectifier voltage drop, ~.7v/rect.
    Max.
  20. Alec_t
    Sep 17, 2013
    5,972
    1,135
    You must be. Even without a cap you should see something similar, like this:
