Voltage Range Limiting
kchrisc
Joined Jan 12, 2013
Is there a way to control a voltage in a circuit so that it only passes to another part of the circuit a certain voltage range? Voltages below the low-end of the range and above the high-end are blocked?
I.e. a circuit that can use a 4V to 5V (these voltages are just examples) source but ignore anything below or above those voltages.
I've thought of JFETs and diodes to create a high-end or low-end but can't seem to workout what to use to create a usable range only.
kchrisc
Joined Jan 12, 2013
Thanks for the replies however I need to constrain voltage to between a range. If the voltage supplied to this part of the circuit is below a certain point it is ignored and if it is above a certain voltage it is also ignored. I haven't had much luck in figuring this out on my own.
4v
---->4V
Pass 4 volts
4.5v
---->4.5V
Pass 4.5 volts
5v
----X0V
No pass 5 volts
Thank you.
thatoneguy
Joined Feb 19, 2009
6,359
Did you see the solution in BillB3857's post? You only need to change the upper and lower voltages to change the range. Look at the output waveforms in the sim, yellow is output, green is input.
