Voltage question
Discussion in 'General Electronics Chat' started by sikter, Feb 7, 2012.
  1. sikter
    Jan 25, 2012
    23
    Hello!I am going to use a 4 channel radio receiver
    (2,4 gHz) in my simple circuit to operate 4 relays.
    Reciever initially came from RC helicopter with
    3,7 V battery.
    How much can I vary the voltage without
    distroying my receiver.
    I got planty 5V DC relays which I would like to
    use. All relays are of momentary type and they'll never
    be engaged longer than a split second at the time.
  2. mcgyvr
    Oct 15, 2009
    4,798
    979
    Knowing nothing about your receiver anything would just be a guess.. so
    A 5V relay won't switch at anything lower than maybe 3.8V (pick up voltage)
    I'd suggest 3V relays or switching a transistor/5V supply to use the 5V relays.
  3. Mark_T
    Member
    Feb 7, 2012
    47
    8
    You will not damage a 5V relay by switching it with 3.7V, its just that it may not switch because the field strength is to weak. If you only have 3.7V then try them if you can put up with them not being 100% reliable then ok. Chances are they will either work or not. Also, be aware that if the battery voltage falls they will at some point stop functioning.
    If not then get lower voltage ones or boost the voltage.
  4. BJT_user
    Member
    Oct 9, 2011
    35
    8
    If you power your receiver wtih 5 volts, you will likely fry it, however, if you try to switch your relays with 3.7 volts, then they probably won't activate. I would suggest using a 6 volt power source (only because it's easy to produce VIA 4 alkaline batteries) and a LM317 variable voltage regulator to reduce the voltage to 3.7 volts on your receiver. Of course you'll have to use a simple voltage amp (single transistor and base resistor) to activate each relay, as well. It's a bit of a complex solution, but workable.
  5. sikter
    Jan 25, 2012
    23
    Thank you!
  6. Von
    Oct 29, 2008
    65
    How are you planning to drive these relays coils?
  7. sikter
    Jan 25, 2012
    23
    I'm going to have 4 momentary switches on my radio transmiter!
    When reciever gets a signal from the radio it will engage
    one of my 4 ralays. The relay is momentary too and it
    will close my main circuit for a just a moment.
    That's all I need. The other three ralays work same way.
    They are connected to other 3 channels.
    I have already connected this sistem and it's working but with 2 channels radio.
    Receiver has 6 V Power supply and my relays have 5V coils.
    Now I need 4 functions and I can't buy cheep radio receiver which
    works on 6V. So I am checking my other options!
  8. Von
    Oct 29, 2008
    65
    Cool!
    What I mean is what are you using to convert the PWM to a DC voltage for relay coil activation. I have seen devices for about $20 to do this but am interested in your design concept.
  9. sikter
    Jan 25, 2012
    23
    Sorry I wasn't paying enough attention lately.
    I don't know what PWM is, but it's probably something what's already integrated into my receiver. I measured the voltege on the circuit card while pushing joystick on the remote controler. I found points where I have to solder the wires what lead to my relays. That's all, I don't know anything about things on the circuit card.
    Can you post a linkt to those 20$ devices? I can't find it.
    Reason that I made my own is because devices I found on the marked were very expensive.
    I spent about 30$ to bulid my own device
  10. Von
    Oct 29, 2008
    65
  11. sikter
    Jan 25, 2012
    23
    Thank you very much,
    I am glad I didn't read this earlier, this would stop me of even trying.
    But I tried and it worked. After reading this one more time my explanation is that those pulses from receiver give enough voltage to engage my relay just for a moment (which is what I needed in the first place)
    "Picoswitch" you showed me is real thing for this job but it would be more expensive solution. (I would be needing four picoswitches which would cost me 80$ + radiotransmitter)
    I payed 35$ for my 4 channel radio, 4 channel receiver and 4 relays.
    It looks that those radio receivers are very flexible regarding the voltage.
    I run it on 4.5V, 6V, 7.4V and 9V. It worked regardlessly, which gave me more flexibility to select the relays.
    Off course, the time will show how close to its limits I've been pushing it.
  12. Andreas
    Jan 26, 2009
    68
    Von has it spot on. Good information and links.
    Thanks.
