Voltage question
Discussion in 'General Electronics Chat' started by BigD, Oct 9, 2006.
  1. BigD
    Oct 9, 2006
    So I know a voltage can be negative with respect to another relatively higher voltage, but can a voltage ever be lower than or negative with respect to earth ground (0 volts).
  2. pebe
    Oct 11, 2004
    628
    Yes it can. A simple example would be where you connect the +ve pole of an AA cell to ground. Its -ve connection will then be at a potential of -1.5V relative to ground.
  3. jtodd5781
    Sep 29, 2006
    6
    Yes it can be negative in respect to ground.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    An AC signal is both positive and negative with respect to ground.
  5. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    And a Split Rail supply (common in Amplifiers and also PC supplies) has both Positive AND Negative rails with respect to ground.
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Here's another way of looking at it: "Negative" and "positive" simply indicate whether current would flow to the reference or from the reference as a result of the potential.
