Voltage output between 0 - 3.3V @ ±0.1V
Discussion in 'Homework Help' started by JoshGreen, Feb 20, 2015.
  1. JoshGreen
    Apr 18, 2013
    11
    For a project I am required to use a sensor to generate a continuous signal varying between 0 - 3.3V, and it has to drop to at least 0.1V and raise to 3.2V.
    I'm using an Ultrasonic Rangefinder and have managed to get a steady dc level from the output that ranges between 0.3V - 2.3V. Using a non-inverting amp would get me 3.3V but I'm struggling to get the voltage below 0.3V.
    I've looked at differential amps but I haven't managed to get one working. So far I don't have anything apart from failed attempts so any help pointing me in the right direction would be great!
    I have access to pos/neg rails but in the project I would have to a 7660 to generate the negative rail as we're only allowed to use a positive 5V supply.
    I've trawled most of the google hits already and not found much to help me, but I may have been looking at the wrong things. Any links and/or explanations would be great! Thanks
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    You need to use an opamp which is advertised as being (at least) rail-to-rail output.
    Download the data sheet for the opamp you are actually using, and read about its range of output voltage relative to what voltages its supply pins are tied to...
    post your schematic.
  3. shteii01
    Feb 19, 2010
    3,500
    511
    I am not sure that will work. Remember, his sensor outputting minimum of 0.3 volts. He needs minimum of 0.1 volts.
    OP, I am thinking you need a different sensor. Or you need to setup several circuits. Each circuit for specific range of sensor output.
    Ah! Run the sensor output though voltage divider. This way you will produce the 0.1 volts output. So your 0.3 volts will be reduced to 0.1 volts, and your 2.3 volts will be reduced to about 0.7 volts.
    What do you need the output of the amplifier to be?
  4. JoshGreen
    Apr 18, 2013
    11
  5. JoshGreen
    Apr 18, 2013
    11
    I made it but its basically dividing it and then multiplying it straight after. The circuit above uses an offset and I think that might work better. I'm gonna try that one out a little more. The biggest problem is that it inverts the output into the 0 - -3.3V range. Can that circuit be done non-inverting?
  6. MikeML
    Oct 2, 2009
    5,451
    1,066
    It is very easy to build a single opamp circuit that has this transfer function:
    Vout = 1.65*Vin - 0.495 (Gain and offset)
    Note that for Vin=0.3, Vout = 0
    and Vin= 2.3, Vout = 3.3
    Since this is home work, I am going to let you try without just showing you the circuit. Hint: it uses one opamp in the non-inverting configuration, two resistors, and an offset voltage.
  7. joeyd999
    Jun 6, 2011
    2,756
    2,916
    Maybe this article from Bob Pease will help.
  8. JoshGreen
    Apr 18, 2013
    11
    Mike ML,
    Thanks to your hint I managed to get this circuit which works perfectly, so thank you!
    The only problem is that I used your vout = 1.65*Vin - 0.495 to get me started and to calculate the values.
    How did you derive those values?
    I've had to change the sensor position which has changed the min/max readings.
    Thanks for all the help so far!
  9. Jony130
    Feb 17, 2009
    3,990
    1,115
    Straight line equation
    Av = Vout/Vin = (3.3 V - 0V)/(2.3V - 0.3V) = 1.65V/V ( the slope)
    And
    0 = 1.65 * 0.3 + x
    1.65*0.3 = x
    x = -0.495
    So we and up with Vout = 1.65*Vin +(- 0.495) = 1.65*Vin - 0.495
    http://www.ti.com/lit/an/sloa030a/sloa030a.pdf
  10. ScottWang
    Aug 23, 2012
    4,925
    777
    How to using op amp to get a low voltage.
    +V → R1 → VR1 → VR2 → R2 → -V
    The pin 2 of VR1 connecting to op amp, and the op amp wiring as a voltage follower.
    VR2 is a small trim pot 100Ω or 200Ω, adjust VR2 to make output to zero or close to zero, it depends on what you want, using VR2 to control the voltage range you want.
