voltage operated relay
Discussion in 'Automotive Electronics' started by turbo1600, Jan 12, 2016.
  1. turbo1600
    Jan 12, 2016
    hi, after a schematic that will turn on a relay at about 13.2 vdc and stay on , until voltage drops to about 12.8 then turn of .,
    anyone help ?
    mark k
  2. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    For the average magnetic relay you would need to set up a comparitor circuit as the hysteresis of the average relay is way more than that.
    Max.
  3. #12
    Nov 30, 2010
    16,705
    7,355
    True. The last time I looked, an automotive relay was guaranteed to pull in at 80% of the label voltage and persist below 50%.
  4. crutschow
    Mar 14, 2008
    13,509
    3,385
    You could use two LM339 or LM393 comparators in a window comparator configuration to control a transistor driver that energizes the relay.
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    Here is something I did for somebody about a year ago:
    cork_ie and crutschow like this.
  6. #12
    Nov 30, 2010
    16,705
    7,355
    That's why I save most of my drawings. The same questions come up, year after year.
  7. crutschow
    Mar 14, 2008
    13,509
    3,385
    I like your circuit Mike.
    It's a simple voltage comparator and has a stable-trip point basically independent of the supply voltage.
    I think it meets Albert E's criteria. :)
