Voltage of the cap ?
Discussion in 'General Electronics Chat' started by ranatungawk, Nov 22, 2014.
  1. ranatungawk
    Thread Starter Senior Member
    Oct 30, 2008
    147
    can you guess the voltage of this Cap with the following code ? voltage is not mentioned there
    code: 6Q 105K 2L
  2. Rich2
    Member
    Mar 3, 2014
    57
    What is it out of? You could make a guess based on what it has come out of and then replace with a higher voltage one.
    Then measure the voltage across it when working just to make sure
  3. RichardO
    May 4, 2013
    1,341
    429
    Posting a picture with a size reference always helps identifying caps.
