voltage of collector and base?
Discussion in 'Homework Help' started by no12thward, Jan 23, 2011.
  1. no12thward
    Jan 10, 2011
    30
    how do I go about finding the VOLTAGE of the Collector(Vc) and the Base(Vb) in this collector feedback circuit? Ive found Current of collector(Ic), Emitter(Ie), and Base(Ib). But do I have to account for the 10V Vcc at the top when finding Vc and Vb (before applying Ohms Law)?
    Thanks guys!!!!
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    The current at the emitter is Ic+Ib.
    To find the voltage at collector, multiply collector current by collector resistor, subtract from 10V.
    To find emitter voltage, multiply emitter current by emitter resistance value.
    Base voltage is found with the current through the bias resistor. It is typically 0.6 or 0.7V, to help verify your calculations.
    no12thward likes this.
  3. no12thward
    Jan 10, 2011
    30
    "The current at the emitter is Ic+Ib."
    Even for a collector feedback circuit? I thought Current at the emitter would be (Beta+1)(Ic)? Is that not right?
  4. Ron H
    Apr 14, 2005
    7,050
    657
    I think you have to assume a value for Vbe (0.6-0.7V) in order to solve for the operating point.
  5. Ron H
    Apr 14, 2005
    7,050
    657
    But Ib=Ic/beta. Do a little algebra, and you'll see that both are correct.
  6. no12thward
    Jan 10, 2011
    30
    silly me! you guys are right. Thanks! So my Vce would be somewhere around 4.8V if Ive done my calcs. correct
  7. Ron H
    Apr 14, 2005
    7,050
    657
    Looks good to me.:)
  8. thatoneguy
    Feb 19, 2009
    6,357
    718
    The way I read the OP was that he already had the currents, so the operating point was known (somewhat). If he had zero info, then a SWAG vbe is needed.
  9. Ron H
    Apr 14, 2005
    7,050
    657
    Well, he did say he had found the currents. I missed that. Of course, to find them (unless he found them in a book:D), he had to know Vbe.
    His question was really about using Vcc in solving for node voltages (I think).:eek:
