I have a voltage multiplier circuit (basically a villard cascade design) using several stages of diodes and caps. My output should be in the 500V - 600V range (DC of course) and I believe is working as it is powering the sensor I am using it for.
With that said, I am having no luck measuring it with my 10MOhm input resistance DVM. I suspect such a circuit is easily loaded down, but I'd think 10MOhms would be enough to prevent such a thing. I'd also have to assume that the DVM manufacturer probably made the input resistance as high as possible without limiting the current below that which their A to D could handle.
So what does one do in such a situation?
