I am using a panel mounted digital voltage meter to measure the output of a op amp. The op amp is powered by a 12v linear power supply. When I use a 9v battery to power the voltage meter, everything works fine. When I power the voltage meter with a switch mode 9v power supply, the meter reading goes haywire.
I think this is related to some common reference between the two power supplies. Is there anything I can do to solve this problem? I don't want to need to use a battery to power the meter.
Thanks,
Thanks,
