voltage levels conversion circuit
Discussion in 'General Electronics Chat' started by Ataleph, May 10, 2010.
  1. Ataleph
    Thread Starter Active Member
    Apr 20, 2009
    31
    Hi all,
    Please, help me with a circuit(at transistor level) which should convert a signal with logical "0"=0V and logical "1"=1.2V(or 0.9V) to a signal with logical "0">=0.3V (but not greater than 0.7V) and logical "1"=1.2V. I have two types of supplies 0.9V and 1.2V, any of which can be used or both.
    Thanks in advance. :)
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Re-phrasing your request:
    Is this a homework assignment, by any chance?
  3. Ataleph
    Apr 20, 2009
    31
    Thanks for re-phrasing. Now it is much clearer. I hope someone will provide the solution.
  4. retched
    Dec 5, 2009
    5,201
    313
    What have you done so far? Where are you getting stuck?
  5. Ataleph
    Apr 20, 2009
    31
    So far I have nothing. I need the conceptual design itself, than I will be able to give appropriate values to devices (sizing etc.).
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Is this an assignment given to you by a teacher/instructor/professor?
  7. Ataleph
    Apr 20, 2009
    31
    No, I just need it for a circuit I am building. Why are you asking
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I'm asking because it rather sounded like such a project.
    See the attached; it's merely a simulation. Your mileage with actual components may vary.
    The incoming sawtooth wave is 20kHz. At low speeds, the switching occurs at 0.9v; but at 20kHz you can see the level is a bit off. It doesn't work at all at 100kHz.
  9. retched
    Dec 5, 2009
    5,201
    313
    We want to know where to file the thread.
    Where is the signal you want to boost or adapt coming from? A sensor of some kind?
    Do you need the output linear over the range, or just 2 outputs 0v and 1.2v
  10. Ataleph
    Apr 20, 2009
    31
    Thanks SGTWookie,
    That's what I need.:)
