Voltage level shifter
Discussion in 'The Projects Forum' started by geogho, May 9, 2010.
  1. geogho
    Apr 17, 2010
    Hi, I am new to electronics and need help with a circuit I am working on. I need a voltage level shifter to shift a DC output from an instrumentation amplifier from a voltage swing of -1.5 to 1.5 volts, to 3.5 to 5.5 volts for the inputs of a dsPIC. Can anyone help me with this?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Use a summer circuit as an input to an opamp wired as a voltage follower (output connected to inverting input).
    You'll need to sum the output of the instrumentation amplifier with an accurate +5v reference.
    See this section of our E-book:
    http://www.allaboutcircuits.com/vol_3/chpt_8/8.html
  3. geogho
    Apr 17, 2010
    Thanks Sgt Wookie, that was helpful.
    Geogho
