Gents,
I looking at the LM3914 or a Quad Op Amp for the following result from a single analog line:
9V = turn on PNP FET or BJGT to short DC motor terminals
10V = turn on PNP FET or BJGT to short DC motor terminals, Turn off 2 of 4 in Series LED (came on at 5 volts),
12V = Funcs of 9V, 10V off, Turn on NCh Fet for DC motor
14V = Funcs of 9V, 10V off, Turn on NCh Fet for DC motor, Turn on 4 of 4 LEDs at lower current/brightness
The steps can be modified if needed. I like the idea of using the "dot mode" in the LM3914 for built in auto turn off of functions, but am concerned whether I have control over the steps/range (get 1-2 volt per step?).
I can go with the OpAmp, but have to do all the turn off stuff manually which is doable.
I want low part count, simple analog function, which method do you guys recommend? Know of projects like this? I searched the forum, but did not see an answer.
Sincere thanks,
MTI
Sincere thanks,
MTI
