Voltage Indicator - Op-Amp, Zeners Or?
Discussion in 'The Projects Forum' started by uponone, Mar 10, 2011.
  1. uponone
    May 18, 2010
    10
    I am hoping someone can help me out with a voltmeter circuit I am working on. The purpose of this circuit is to monitor a 7.2V battery. I do not want to use an external power source to run the unit and since I am trying to keep this as cheap as possible I would like to avoid the LM3914.
    This circuit will light 4 leds at the following voltages:
    7v - green led on
    6v - green led on
    5v - red led on
    4v - red led on
    (I want to use a bar type mode not dot)
    I am new to electronics so bare with me if my questions seem silly.
    From the research I have done on Google, it seems I should be using a LM324 op-amp but I am confused because some sources say this MUST be used with a separate power supply. Is this true? I have attempted to read the datasheet for LM324 but it is over my head.
    I have found this schematic that seems to be what I need:
    http://circuitzoo.com/2010/08/24/electronics/car-battery-voltmeter-circuit-diagram-using-lm324.
    Can I use this? If so, what would I need ot modify in order to measure the specified voltages and change the input to 4-7.2v? I am still wrapping my head around voltage dividers so I haven't been able to calculate the correct resistors. I would also like to get rid of the trim-pot if possible.
    Would I be better off using some zener diodes to construct this ciruit?
    Thanks for the help,
    Chris
  2. jean_all
    Mar 8, 2011
  3. uponone
    May 18, 2010
    10
    Hi jean_all,
    Thanks for taking the time to reply. That comparator looks promising. Do you know if they manufacture a 4-channel version?
    Chris
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
