voltage gain of a transistor amplifier
Discussion in 'General Electronics Chat' started by dumindu89, Sep 6, 2012.
  1. dumindu89
    Oct 28, 2010
    113
    1. How to find the small signal AC voltage gain of a transistor (NPN) amplifier in common emitter configuration which has a emitter resistor (Re) with a capacitor (Ce) parallel with emitter resistor around 100 MHz?(transistor is BFR520, gainbandwidth product is 9GHz)
    2. What will be the case if the Ce capacitor is not there?
    3. Is it possible to get a small signal voltage gain of 25 at 100 MHz from BFR520 with the configuration stated above or what configuration will be the most suitable for this?
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  3. dumindu89
    Oct 28, 2010
    113
    Hi!
    Thanks for the fast reply.
    What is the гl and гs stated in that document?
