voltage formula?
Discussion in 'Homework Help' started by wil321, Mar 8, 2011.
  1. wil321
    Mar 8, 2011
    6
    I don't know how to figure out the value of this voltage formula:
    Vs= 10sin(2xpiexf)t
    There is a forward bias diode in the circuit
    followed by the one resistance in the circuit is 100k ohms.
    The frequency is 100hz,
    Can someone help?
  2. Robert.Adams
    Feb 16, 2010
    112
    5
    It sounds like you're talking about a half wave rectifier with a 100k resistor hooked up as a load.
    The diode will be reverse biased on the negative swing of the sine wave so the voltage across the resistor will be 0 since the diode will stop current flow. When the input voltage is between 0.7V (Forward Diode Voltage assumption) and the maximum of 10V, the voltage across the resistor will be the source - 0.7V.
  3. wil321
    Mar 8, 2011
    6
    Thanks.
    So what would the PEAK VOLTAGE be if we ASSUME there is no voltage drop across the diode?
  4. Adjuster
    Dec 26, 2010
    2,147
    300
    In your first post, you stated that Vs = 10sin(2pift)
    What is the maximum possible value for a sine?
    http://en.wikipedia.org/wiki/Sine
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    Remember: On the positive half-sine of the input, the output voltage is equal to the input. On the negative, the output is zero.
