voltage follower
Discussion in 'General Electronics Chat' started by jjkk, Jan 20, 2009.
  1. jjkk
    Jan 16, 2009
    12
    can i input a sine wave from asignal generator to a op amp voltage follower
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    A qualified...yes.
    More details???
    Ken
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Of course it can be led in as an input, but without any details it's impossible to say how any op amp would respond.
  4. jjkk
    Jan 16, 2009
    12
    i am using the voltage follower to drive a transformer(basically 2 coils wound in a tube) .there is parallel LC circuit to resonate it. but i am not getting anything. how will i drive the transformer to get a better output
  5. KMoffett
    Dec 19, 2007
    2,584
    234
    How about posting a schematic?
    Ken
  6. jjkk
    Jan 16, 2009
    12
    i only have a scribbled schematic. i can describe it. signal generator-voltage follower-capacitor parallel to the primary -output from secondary.can anyone tell me how to drive the coils to get a better output
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You probably need a more capable source to drive the transformer. We need details to assist with your problem.
  8. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Two coils wound on a tube might not give a very good k value. K is the efficiency of the transformer, always less than 100%.
    Are the windings one atop the other? Separated? Wound together with the conductors side-by-side?
    Is the tube of powdered ferrite? Iron? Plastic?
    What frequency are you injecting?
  9. jjkk
    Jan 16, 2009
    12
    the winding are separated.the tube is an insulation material i used a ferrite piece to go thru it.when it reach the middle of the coil it gives o/p
  10. kubeek
    Sep 20, 2005
    4,688
    806
    What frequency do you use? What value is the capacitor? Is it electrolytic or some other type?
    If you don´t answer our questions, we can´t help you.
  11. jjkk
    Jan 16, 2009
    12
    i am using 22kHz sinewave . i calculated the capacitor value as 0.3uF. so it resonates at a that frequency.but the output is disturbed.
  12. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What is the impedance of the transformer primary? Can your signal generator drive that load?
  13. kubeek
    Sep 20, 2005
    4,688
    806
    The capacitor has to be ceramic or film, polarized electrolytic cap will distort one polarity of the sine wave.
  14. jjkk
    Jan 16, 2009
    12
    impedence is arround 170uH. i am using non polariced capacitor . do i have to increase the no. of turns to get better performance
  15. Audioguru
    Dec 20, 2007
    9,411
    896
    An opamp can drive an impedance of 2k ohms and higher.
    A lousy old 741 opamp works at frequencies of only 9kHz and lower.
