voltage follower
Discussion in 'Homework Help' started by kahafeez, Jan 16, 2009.
  1. kahafeez
    Thread Starter Active Member
    Dec 2, 2008
    150
    hi plz help me with the described problem.....
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    I'm not sure what the problem is? You want to reduce the output voltage to ¼ of it's original value?
  3. kahafeez
    Dec 2, 2008
    150
    yes thats right, but i'm afraid that by attaching two resistors the oscillations might die as well....
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Why would it? Op amps have extremely low output impedance, so that shouldn't be a problem. This is homework, so I won't give the answer, but you have way too much attenuation on that voltage divider.
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    I agree with Bill that this looks like classwork for a course. I have moved it to the homework forum.
    hgmjr
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    The Wien Bridge Oscillator needs a gain of 3.
    If the pot is set to a little more than 4.3k (close to half) then the gain is perfect.
    A voltage divider at the output of a 10k resistor in series with a 3.3k resistor will have 0.248 times the output across the 3.3k resistor if the load current is zero.
  7. Ron H
    Apr 14, 2005
    7,050
    657
    :confused:
    AG, I think your mental calculator has failed you. The pot needs to be set to 8.6k for a gain of 3.
