From the above equation the voltage across the resistor is a function of time, so it is pretty essential to the question - could it be asking you for the initial or final voltage across the resistor?thanks but the time is not given
For the final voltage, and in the absence of a specific time, in the above equation use t = \(\infty\), therefore you get:it is the final voltage across the resistor
by Robert Keim
by Jake Hertz
by Duane Benson
by Jake Hertz
