Voltage Drop Confirmation
dineshhx
Joined Jan 10, 2015
Asking you guys because i would like to confirm the voltage drop for following datas.
copper wire with length of 120ft
input load : 20A
When i check voltage drop from Easycalculation.com
The calculator shows result as "1.2 volts". Is the answer value is correct for my automatic POWERON circuit?
Kindly help me to use the exact voltage drop for my digital circuit.
34,470
It entirely depends upon the wire gauge, which you did not state.
What does an automatic POWERON circuit have to do with it? :confused:
#12
Joined Nov 30, 2010
18,224
My chart shows that 12 AWG wire has 1.588 ohms per thousand feet at 20 degrees C.
That and Ohm's Law will get you an answer.
