Voltage drop across a resistor in an open circuit?
Discussion in 'Homework Help' started by sayeo87, Aug 30, 2007.
  1. sayeo87
    Aug 30, 2007
    Hi, as seen in the problem below, I need to find the voltage drop across the resistors when the switches are open. I know that voltage across a break is equal to the supplied voltage. But how about across a resistor?
    Thanks for any help.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    E = IR. Since I = 0, so does E.
  3. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    When the switches are open the resistors are not connected to anything so they don't get anything. Answer is 0
  4. Distort10n
    Dec 25, 2006
    429
    For this exercise the answer is 0V. Practically, the switch is not infinite impedance when open, so there will be a VERY tiny voltage drop.
  5. mOOse
    Member
    Aug 22, 2007
    20
    The kind of break you are talking about is a completely different situation.
    For instance, consider the break caused by the open S1. There is voltage
    across it because the terminals of S1 are connected appropriately with a
    voltage source.
    However, both sides of the resistors are not in contact with the voltage
    source when the switches are open, so no voltage can appear across them.
    BTW, none of questions a, b, or c actually ask what happens when both
    switches are open!
  6. recca02
    Apr 2, 2007
    1,211
    for the first case.
    v1 = 30/3 v2=0
    for case 2
    v1=0; v2=20
    for case 3 (apply superposition)
    v1= 10/r
    v2=20/r
    i solved this by mere observation if any correction by any one please reply
  7. techroomt
    May 19, 2004
    198
    all good mr recca, except i like V1 = 10v and V2 = 20v for case a.
  8. recca02
    Apr 2, 2007
    1,211
    yeah i see that now,
    wonder whether it was negligence or a typo on my part.
    thanks anyways.
  9. steeve_wai
    Sep 13, 2007
    47
    there is no voltage across that resistor simply because it is not connected "PROPERLY" to any voltage source in this circuit.hence no voltage is "experienced" by that resistor. i=v/r,v=0.so i=0.
  10. cheenu
    Apr 11, 2007
    there are 2 loops........
    consider 2 loop current flowing thru each.......
    [B]case1[/B]
    the 2nd loop is opened hence there is no current thru it .......
    hence consider only the 1st loop.......with R and 2R resistors......and Vs1.......
    see the resistance......
    one is double of the other one.
    hence vltge drop across 2R will be DOUBLE of that across R....
    since V1 = IR...........(1)
    and V2 = I*(2R)
    HENCE.... V2/2= IR..........(2)
    FROM (1) & (2)
    V1=V2/2
    2V1=V2
    APPLY KVL....
    VS1=V1+V2
    30= V1+2V1
    30=3V1
    THEREFORE V1=10V
    HENCE V2=20V...........SINCE V2=2*V1
    CASE2
    SIMILARLY.
    FOR THE SECOND CASE....
    1ST LOOP WILL NOT BE PRESENT......
    AND R IS PARALLEL WITH VS2...
    HENCE V2=VS2=10 OR 20 WATEVER IS GIVEN.....
  11. 85db
    Mar 2, 2008
    Since the drop across 2R is 0, does it mean that if I measure the voltage across the open switch S2, I'll get all 20v?
  12. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Yes. The open switch is an insanely large resistance, so it drops all the voltage.
  13. recca02
    Apr 2, 2007
    1,211
    Thats a much better explanation than "the whole voltage appears at the terminals" for people who are confused.
  14. japj
    Sep 17, 2009
    there is no way to figure it if you do not know what the resistance or amps are. unless you figure R and 2r as anything you pick out. E/I*R so you have to know 2 of these
