Voltage Doubler Arrangements
Discussion in 'General Electronics Chat' started by haditya, Apr 1, 2004.
  1. haditya
    Thread Starter Senior Member
    Jan 19, 2004
    the other day i came across these voltage doubler and tripler arrangements using diodes. unfortunately no explaination was provided for the same on the site.
    so i need to know -what is their function?? do they really double voltage?? where are they used
  2. Battousai
    Nov 14, 2003
    Are you talking about "bootstrapping?"
    Imagine you have a capacitor with one end tied to ground, and the other tied to a voltage source V1. You charge (assuming some finite resistance through the wire) up the capacitor to a voltage V1. The charge stored on the capacitor is Q1 = C*V1. Then you disconnect the ground connection and in it's place you connect it to a voltage source with voltage V2 < V1. Now the capacitor begins to charge up again until the voltage across it is V1, the charge added to the capacitor is C*(V1-V2). Now you disconnect both voltage sources from the capacitor and reconnect the one end of the cap to ground. The voltage across the capacitor is now 2V1-V2, and since V1 > V2, 2V1-V2 > V1. So in essence you have increased your voltage above the original source V1.
    Maybe you could post a schematic of the circuit you are talking about?
  3. mozikluv
    Jan 22, 2004
    :) hi haditya,
    am attaching an article about voltage doubler :)
  4. haditya
    Jan 19, 2004
    :huh: :unsure:
    i guess i'll need more info on that
