voltage doubeler with capacitors
Discussion in 'General Electronics Chat' started by ripadisc, Aug 31, 2016.
  1. ripadisc
    Aug 31, 2016
    Hey guys trying to double my voltage from 24 to around 48v to run a grid tie inverter can this be done with capacitors
  2. crutschow
    Mar 14, 2008
    13,501
    3,375
    How much current?
    Capacitive voltage doublers only work well for small currents.
  3. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    ................unless you use really huge capacitors and a high frequency drive waveform.
  4. kubeek
    Sep 20, 2005
    4,689
    806
    ... and are prepared to have very low efficiency.
  5. ian field
    Oct 27, 2012
    4,447
    791
    The triplers in TV sets didn't run particularly hot - the diodes in the early ones were long paxolin tubes full of hundreds of little selenium rectifier pellets.
    They're not inefficient if you design them properly.
    A double charge pump used to be the favourite method to make dual voltage SMPSU rectifier/reservoir circuits - they didn't run particularly any hotter than just a bridge rectifier charging the reservoir.
  6. kubeek
    Sep 20, 2005
    4,689
    806
    I meant that in the way of this conundrum http://www.smpstech.com/charge.htm In the first picture lets say you have 1F at 1v which is 0.5J of total energy, but after the switch closes you get twice 1F at 0.5V = 0.125J so total energy of 0.25J. When you charge a capacitor by paralleling it with another capacitor, you lose half or less of the energy in the resistance.
    That is also why step down SMPS uses an inductor as well as acapacitor, instead of just doing PWM into a capacitive load.
  7. ian field
    Oct 27, 2012
    4,447
    791
    In most SMPSU topologies - the output side capacitor has nothing to do with conversion, its simply a LPF.
