Voltage division question
Discussion in 'Homework Help' started by Henry Jyrkinson, Feb 17, 2015.
  1. Henry Jyrkinson
    Feb 17, 2015
    Hi here is my problem
    So I need to solve Vout.
  2. shteii01
    Feb 19, 2010
    3,500
    511
    Are R1 and R4 in parallel?
  3. Henry Jyrkinson
    Feb 17, 2015
    Yes they are.
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    Write a KCL equation for the current in/out of node(Vout).
  5. crutschow
    Mar 14, 2008
    13,488
    3,372
    You can also convert each parallel pair of resistors to the equivalent single resistance and solve the voltage from that.
  6. WBahn
    Mar 31, 2012
    18,085
    4,917
    There's only one pair of resistors in parallel.
  7. crutschow
    Mar 14, 2008
    13,488
    3,372
    The op stated that R1 and R4 are in parallel.
  8. WBahn
    Mar 31, 2012
    18,085
    4,917
    Yes. R1 and R4 are in parallel. Those are the ONLY two that are in parallel.
    R2 and R3 are NOT.
  9. crutschow
    Mar 14, 2008
    13,488
    3,372
    You are correct of course. Silly me, as you might have guessed, I didn't closely look at what I thought were two ground symbols. :oops:
  10. WBahn
    Mar 31, 2012
    18,085
    4,917
    We've all done it. And we will all do it again. And again.
  11. Dodgydave
    Jun 22, 2012
    5,150
    769
    Work out the parallel resistance, (20K) then remove the resistor to ground (R3),and work out the current across the 90V supply, then work out the voltdrop across R2, subtract the 30V and that should be it...
  12. WBahn
    Mar 31, 2012
    18,085
    4,917
    On what basis are you removing R3?
  13. JoeJester
    Apr 26, 2005
    3,400
    1,218
    I'm sure glad Henry Jyrkinson will get a good grade after all the work he's done to solve this problem.
  14. WBahn
    Mar 31, 2012
    18,085
    4,917
    Well, I guess we can give credit where credit is due -- he DID come back and answer one of the clarification questions that was asked. That's better than most!
    He's also had to deal with some false hints, which can be frustrating but also very educational.
    Still, I'm with you -- need to see some effort from him if there is much point going any further.
