Voltage Divider
Discussion in 'General Electronics Chat' started by Lightfire, Dec 10, 2011.
  1. Lightfire
    Oct 5, 2010
    690
    21
    Just read the voltage divider on AAC ebook and found it is interesting.:):):)
    Now, can somebody look at my schematic and check if the lights would light...
    Thanks everybody....
  2. crutschow
    Mar 14, 2008
    13,498
    3,374
    I don't see that the resistors serve any useful purpose. The three bulbs are in series with the 60V battery. The resistors only serve to draw addition current from the battery without performing any other function.
    Don't know why it's called a voltage divider.:confused:
  3. Adjuster
    Dec 26, 2010
    2,147
    300
    Parallel resistors might in principle be used to allow lamps of different current ratings to be used in a series circuit. In practice however the different lamp types might heat up at different rates, and due to the large change in resistance with temperature, some lamps could suffer excessive voltages at every switch-on, shortening their lives.
  4. wmodavis
    Oct 23, 2010
    737
    150
    It depends on the specifications of the bulbs, i.e. their resistance, and voltage and or power rating and how you define 'light' (from dim to normal).
    You show current/voltages in the diagram but those are based on the resistances of the resistors only with the bulbs not being present. The bulbs are in fact resistors too and you have not defined their specifications. Unless you know their characteristics you cannot determine from the information given what will happen.
    Incandescent lamps will likely have resistance values much lower than the resistors you show in parallel with them so they will therefore be the main determinors of the voltage drops around the loop and the resistors will not have much effect.
    In short the voltages and current shown are not correct unless the bulbs are removed from the circuit shown. And it is not possible to determine if the bulbs will light unless you provide their specs. Bulbs usually have a voltage and wattage associated with them.
  5. Adjuster
    Dec 26, 2010
    2,147
    300
    I should have looked at the resistor values before commenting! Something you need to understand is that ordinary incandescent filament lamp bulbs generally require at least some tens of milliamps to operate. Often their current ratings are much higher than that. Here are a couple of examples:-
    A very small indicator lamp, of a kind that was more common before LEDs were available, might be rated at 12V, 20mA: a power rating of 0.24W. That is equivalent to a resistance of only 60Ω.
    More powerful 12V bulbs use more current, and so are equivalent to lower resistances, for instance a 12V 60W car headlamp bulb would draw about 5A, and would be only around 2.4Ω resistance.
  6. Lightfire
    Oct 5, 2010
    690
    21
    Heya,
    The bulbs specifications are theer. :D the specs of the resistors are not indicated there.
    Lamp 1 specs=0.0027 amps / 13.636 volts
    Lamp 2 specs=0.0027 amps / 24.5448 volts
    Lamp 3 specs=0.0027 amps / 21.8176 volts
    Actually, I want the bulbs lights normal. :D
    Actually in my calculation, each resistors would produce the same ampere and voltage as the lamps need, respectively. :D
    need confirmatioon pls.
  7. crutschow
    Mar 14, 2008
    13,498
    3,374
    Yes, that's obviously what the circuit is trying to do. I missed that completely.:p
    But for the given values of bulb voltages and current, the resistors serve no purpose. The bulbs would draw that current and drop those voltages without the resistors.
    How can the bulb voltage be spec'd at 3-4 decimal places? Those voltages appear to be what was calculated, not what the bulb requires. What are the actual bulb specs?
  8. ifixit
    Distinguished Member
    Nov 20, 2008
    639
    110
    Hi Lightfire,
    No. All the bulbs are burned out:rolleyes:. Only the resistors are drawing current.
    Regards,
    Ifixit
  9. Lightfire
    Oct 5, 2010
    690
    21
    Actually, the bulbs' specs are exactly the same as what the resistor would give volts and amps..
    need clarification,pls.
  10. thatoneguy
    Feb 19, 2009
    6,357
    718
    After the first resistor, there wouldn't be any current for the next to bulbs to light if the first bulb failed.
    Since they are different voltages, you should wire the bulbs in 3 parallel sets, each bulb has it's own series resistor, like an LED chain.
