voltage divider
Discussion in 'Homework Help' started by alexander7, Feb 25, 2010.
  1. alexander7
    Oct 11, 2009
    1 .The totle resistance of a series circuit is 500Ω . what percentage of the totle voltage appears across a 22Ω resistor in a series circuit?
    Please explain!
    Thanks :confused:
  2. jlcstrat
    Jun 19, 2009
    58
    To find the drop, take the resistor you're looking for divided by the total. Then multiply that be the total voltage.
  3. shteii01
    Feb 19, 2010
    3,500
    511
    I am getting 4.4% of total voltage appears across 22 Ω resistor of the voltage divider.
    Basically. V is your total voltage.
    V==100%
    Voltage across 22 Ω resistor is (22/500)V, just like jlcstrat said. Then.
    (22/500)V==x%
    You know value of V, put that value in the equation and crunch the numbers.
