Voltage Divider
Discussion in 'Homework Help' started by Steve1992, May 7, 2006.
  1. Steve1992
    Thread Starter Senior Member
    Apr 7, 2006
    100
    Vout = Vin x R2 / (R1 + R2)
    If Vin is 12V and I want Vout to be 4.5V
    What would the equation/math be to find the values for R2 and/or R1 if given.
    If R1 is given R2 would be a common factor?
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    There is no unique solution. There must be some other condition. For example R1 + R2 must be 20K Ohms. Now there is a unique solution because you have two equations and two unknowns.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Duplicate -- Delete
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Duplicate -- Delete
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Duplicate -- Delete
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Duplicate -- Delete
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Duplicate - Delete
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Duplicate - Delete
  9. radiosmoke
    Member
    May 30, 2006
    17
    Et = 12v
    you need to know the current. so use .1 amp arbitrarily.
    It = .1amp
    find R1 and R2
    by using Rt = Et/It or 12v/.1amps
    = 120ohms total resistance
    if you want 4.5 volts then R1 = 4.5v-12v = 7.5v drop
    7.5v / .1amps = 75 ohms = R1
    4.5v / .1amps = 45ohms = R2
    the same curent flows through both resistors. so that is used to find the total resistance
    and ratio is used to find voltage drops
    and resistances are in proportion to current.
