Voltage Divider with variable load
Discussion in 'Homework Help' started by testing12, Jan 30, 2011.
  1. testing12
    Jan 30, 2011
    80
    Hello, can someone please help me create the following curcuit? Id like to know the steps so i can to solve this. I dont seem to be getting the correct answer its very frustrating because it seems so simple. please advise.
    Thank you!
    Here is my attempt which is completly wrong.
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    For IL = 5mA we want Vout = 5V ±0.5V
    So for RL = 4.5V/5mA = 900Ω
    For IL = 0A we want Vout = 5V
    And from thevenin Vth = 5V and Rth = 0.5V/5mA = 100Ω
    Rth = R1||R2 = (R1*R2) / (R1+R2) = 100Ω
    Vth = 15V * R2/(R1+R2) = 5V
    R1/R2 = 2 and (R1*R2) / (R1+R2) = 100Ω
    Is this enough?
  3. testing12
    Jan 30, 2011
    80
    Im sorry im very new at this, i dont understand what your are doing from the 4th line on.
    That is, from here:
    "And from thevenin Vth = 5V and Rth = 0.5V/5mA = 100Ω
    R1/R2 = 2 and (R1*R2) / (R1+R2) = 100Ω"
    I dont know what Vth and Rth represent and where the 0.5 Volts comes from. I know the max allowables are 5.5 V and 4.5 V but dont understand why the 100 ohms is needed and what is being done with this value. Im verry sorry as i mentioned im very new at this.
    Thank you for your reply.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    According to the specification, this could be 5.5V, which will allow less power to be wasted in the divider.
  5. Jony130
    Feb 17, 2009
    3,993
    1,116
    Do you familiar with thevenin's theorem?
    Vth represent Vout voltages for IL = 0A
    And now if we connect a load 5mA and Vout drops to 4.5V
    then internal resistance Rth is equal (5V - 4.5V) / 5mA = 100Ω
    And Rth - represent R1 and R2
    Rth = R1||R2= (R1*R1)/(R1+R2)
      File size:
      6.1 KB
      21
  6. Jony130
    Feb 17, 2009
    3,993
    1,116
    But algebra will be much simpler for 5V.
  7. Ron H
    Apr 14, 2005
    7,050
    657
    Is that a good reason for wasting power?:rolleyes:
  8. Jony130
    Feb 17, 2009
    3,993
    1,116
    Hm, and I'm not so sure about this power wasting.
    For 5V R1 = 300Ω ; R2 = 150Ω
    For 5.5V; R1= 272.727Ω ; R2 = 157.895Ω
    So R_total is equal to 450, and 430.622 . So I really don't understand.
  9. Ron H
    Apr 14, 2005
    7,050
    657
    For 5.5V no load to 4.5V full load, I get Rth=200Ω
    R1=545.45
    R2=315.79
    Exactly half the wasted current relative to your original values.
    I think you forgot to recalculate Rth.
  10. Jony130
    Feb 17, 2009
    3,993
    1,116
    Now I see
    Thx Ron
  11. testing12
    Jan 30, 2011
    80
    Hi guys thank you for all your replies, much appreciated. I will have to solve this with algebra i have not learned thevenin's theorem yet. I will work through the posts to see if i can come to some understand and post an answer if im able to. Once again thanks for all your time.
  12. Jony130
    Feb 17, 2009
    3,993
    1,116
    First
    No load and Vout = 5V---> R1/R2 = 2
    Now with load 5mA Vout = 4.5V
    R1/(R2||900Ω) = 2.333
    So you need to solve this
    R1/R2 = 2 (1) --> R1=2*R2
    2R2 / [(R2*900) / (R2+900)] = (15/4.5V -1)
    (2)
    Solve for R2
  13. Ron H
    Apr 14, 2005
    7,050
    657
    Yeah, you can easily do it without Thevenin's theorem.
    It's just 2 equations and 2 unknowns.
  14. testing12
    Jan 30, 2011
    80
    after following through and solving i got R2 = 1028.57 ohms or 1Kohm
    and R2 = 2057.14 k ohm.
    The probem comes when i try this in the electronics workbench simulator i have, it shows that the voltage drop accross the load is 3 volts when its not supposed to be less then 4.5 volts.
    thanks again for your help guys...
  15. Jony130
    Feb 17, 2009
    3,993
    1,116
    Try again
    2R2 / [(R2*900) / (R2+900)] = 2.33333333
    2R2/1 * (R2+900)/(R2*900) = 2.33333333
    ( R2 + 900 )/450 = 2.33333333
    R2 + 900 = 1050
    R2 = 1050 - 900 = 150
    testing12 likes this.
  16. Ron H
    Apr 14, 2005
    7,050
    657
    Jony130 is pretty stubborn about using 5.0V instead 5.5V for the unloaded voltage. If I were your instructor, I would knock your grade down if you did that. The answer could be correct technically, but it is poor engineering practice. Why not just make R1=2 ohms and R2=1 ohm? It still meets spec, but I'll bet it is not what your instructor is asking for.
    Have you studied Kirchoff's laws? Another way is to use KCL (Kirchoff's current law) to solve the problem.
    See the attached schematic. You should be able to write one equation for the unloaded case on the left, and another for the loaded case on the right.
    I'm not saying this is a better method than Jony130's. Just another approach.
    I'm trying to leave a little of the work for you.
  17. testing12
    Jan 30, 2011
    80
    i see the problem was 2.33 i was not following order of operations.
  18. testing12
    Jan 30, 2011
    80
    Hi Ron,
    yes i have studied KCL and KVL as well as ohms law, i just have never done anything dealing with a variable resistor. I will be studying this in greater detail in about half hour.
  19. Ron H
    Apr 14, 2005
    7,050
    657
    I forgot to label the voltage source on the left hand circuit. Obviously (I hope) it is the same 15 volts.
    Think simultaneous equations.
  20. Jony130
    Feb 17, 2009
    3,993
    1,116
    But if you set Vout = 5.5V and then allow the voltage to drop from 5.5V to 4.5V then the error will be bigger then ±10 ?
    (5.5-4.5/5.5) x 100 = 18%
    But it seems that I'm wrong
