Voltage Divider with the 8051
Discussion in 'Embedded Systems and Microcontrollers' started by sandraos, Jun 25, 2009.
  1. sandraos
    Jun 8, 2009
    12
    Why does'nt the following schematic work? Also, is it possible to use a zener instead? If so, how would I hook it up?
    Thanks for the help,
    Salim
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Voltage dividers only work for a constant load. The current draw of the 8051 varies moment to moment. Use a voltage regulator like a 7805 instead. Google the number and get a data sheet to see how to use one. With a 10 volt source, you may need to mount it on a heat sink to keep heat down.
  3. sandraos
    Jun 8, 2009
    12
    thanks beenthere,
    the 7805 is exactly what i was looking for
