I'm not at the shop. I think I might have four 220 resistors.Would I lie to you?
You have four 220Ω resistors. Why don't you try it? What have you got to lose?
Make sure you twist all four resistors together in parallel.
I thought the gauge was voltage sensitive rather than current sensitive. That is part of why I am having so much trouble. I still think it is voltage and not current that makes that gauge swing.You need to reduce the current to the gauge.
It's both.......................
I thought the gauge was voltage sensitive rather than current sensitive. That is part of why I am having so much trouble. I still think it is voltage and not current that makes that gauge swing. ............
The existing gauge, as per post #18, is already a potential divider, the sender unit being the variable bit. By adding those resistors you are modifying the divider action.Am I making a variable voltage divider by putting the resistors on the input
