Voltage Divider Design
Discussion in 'Homework Help' started by yan500, Jul 17, 2011.
  1. yan500
    Jul 12, 2011
    48
    Hi all,
    Hope everyone's having a great weekend. I have a problem that I'm trying to solve and it's tripping me up. http://www.allaboutcircuits.com/worksheets/e_divide.html
    It is Question 35 on the worksheet located at the link above. Since the problem states that you can assume there is a bleed current of 1.5 mA, I calculated the total current in the circuit to be 13.5 mA. I believe that this is what's throwing me off. Can someone tell me what the total current in the circuit is and how they calculated it?
    Thanks!
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    To get I_total you simply need to add the load current plus the bleeding current.
  3. yan500
    Jul 12, 2011
    48
    Right, but for R3 + Load 1 you get 4.5 mA, which gives you the right answer for R3. But shouldn't the total of R2 + Load 2 give you 4.5 mA as well because of the loop rule?
  4. ian_gregg
    Jan 19, 2011
    21
    There is 1.5mA through R3, 4.5mA through R2 and 16.5mA through R1, you know the voltages, V=IR and away you go.
  5. Jony130
    Feb 17, 2009
    3,990
    1,115
    I don't understand you problem
    R2 = (9V - 4.8V)/4.5mA = 933.3
  6. yan500
    Jul 12, 2011
    48
    Ah, I see. Thank you. But how did you know to subtract 9 from 4.8 to get the voltage going through R2?
  7. Jony130
    Feb 17, 2009
    3,990
    1,115
    Because I know Ohm’s law and KVL/KCL all too well.
    Simply Load 2 need 9V and Load1 needs 4.8V.
    So the voltage drop across R2 must be equal 9V - 4.8V
  8. Jony130
    Feb 17, 2009
    3,990
    1,115
    Maybe this will help you withe KVL
    And remember that if elements are connect in parallel they will have the same voltage across them.
    VR4=V3+V2 or VR4=VB-V1, VR5=VB1, V1+V2=VR2
  9. yan500
    Jul 12, 2011
    48
    Thanks a lot guys. I need to practice my KVL/KCL, I'm so bad at them...
