In the voltage divider circuits article, there appears to be an error; though, I am a novice, so perhaps I don't understand something?
http://www.allaboutcircuits.com/vol_1/chpt_6/1.html
Below this line in the article:
From here, we can use Ohm's Law (I=E/R) to determine the total current, which we know will be the same as each resistor current, currents being equal in all parts of a series circuit:
The chart shows 2m as the result of I; however, with other calculators I've used, I get 1m, not 2m. I'm unable to produce 2m no matter what I do. Can someone clarify or correct this issue?
Thanks very much.
Thanks very much.
