am confused about voltage divider Bias (figure is uploaded) that if i removed R2 resistance then transistor goes in saturation or cut off.
same with the R1, if i removed R1 resistance then transistor goes in saturation or cut off.???
while i remove both the resistor then what is the impact on the circuit.
Secondly, in some circuit i seen that most of the grounds are connected with resistor , i mean they are not grounded directly. they placed the resistor before ground..
kindly help me in this way..
Thank you....
Thank you....
