Voltage Divider Bias circuit usage?
Discussion in 'Homework Help' started by Petrucciowns, Jul 7, 2009.
  1. Petrucciowns
    Thread Starter Active Member
    Jun 14, 2009
    62
    Can anyone give me an example of what a Voltage Divider Bias circuit would be used for. All I can find is theory, but not an example of its operation.
    Thanks.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Focus divider for electromagnetic lens focusing in TV CRT.
  4. hobbyist
    Distinguished Member
    Aug 10, 2008
    772
    61
    Example: of it's operation..
    VCC=10 V.
    Rload = 10K ohms.
    Zin = > 2K ohms.
    Av. = 10
    RB1 is the voltage divider resistor from ground to the base of the transistor.
    RB2 is the resistor from supply to base, to form a "voltage divider"
    Make RC 1/10 Rload = 1Kohms
    make RE = 100 ohms. Av. = RC / RE
    VC = 5 V.
    IC = VC / RC = 5 / 1000 = 5mA.
    5mA X RE = VRE = 0.5V.
    VBE = 0.7V.
    VBE + VRE = VRB1
    0.7 + 0.5 = 1.2V. = VRB1
    Make RB1 = 2K ohms to satisfy Zin parameter.
    ID = divider current = VRB1 / RB1 = 1.2V / 2K = 600 uA.
    RB2 = (VCC - VRB1) / ID
    (10 - 1.2) / 600 uA. = 14.7K ohms.
    make it 15K ohms.
    So RB1 and RB2 form the voltage divider to provide a base voltage of 1.2V.
    so that in turn can cause a emitter voltage of 0.5V. wich ultimately determines the amount of collector current that willk flow through the transistor.
    Now some checking.
    VCC X RB1 / (RB1 + RB2) = 1.17V. = voltage at the base.
    1.17V. - 0.7 V. = 0.476V. at the emitter.
    so 0.467V / 100 = 4.7mA of collector current, assuming emitter asnd collector current are the same in the calculations.
    Hope this is a good example to put with the theories you learned.
    I keep rereading your post and think maybe this isn't the example your looking for afterall. I don't know.
