voltage detection module
Discussion in 'General Electronics Chat' started by solar77, Aug 27, 2011.
  1. solar77
    Aug 27, 2011
    Is there a module that turns the LED one input voltage drops below certain value? even better if this value can be defined in someway.
    the range of detection is 0-12V and accuracy should be 0.1V.
  2. JingleJoe
    Member
    Jul 23, 2011
    185
    10
    What do you mean? That you want your LED to turn on between 0 and 12 volts? Because as far as I know the component for that is called a switch :p
    Op amp voltage crossing detector, look that up, I think it's what you want.
  3. solar77
    Aug 27, 2011
    well, I am looking for a battery level indicator. once the voltage drops below a value, the indicator lights a LED. Hope that make more sense than my previous description.
  4. Smoke_Maker
    Sep 24, 2007
    126
    15
    Try one of these, I use then to detect low voltage in batteries.
    S-80960CLMC-G7W-T2
  5. Jaguarjoe
    Apr 7, 2010
    770
    90
    If its just voltage you want, look through the ebooks at the top of this website and search for "comparator". You will be able to exactly set the trip point you desire.
