Voltage controlled switch
I need a simple circuit that will allow only the 10 volts and up, to actived a relay, when the input is more than 10 volts . The circuit is used to drive a 12v relay.
This is for a car for the (day runing light) Hi beam to instale hid xenon I don't whant they comme on when is 7 volts.
Thanks for any help you can give.
