Voltage Controlled Phase Shift
Discussion in 'General Electronics Chat' started by Robin Mitchell, Nov 13, 2014.
  1. Robin Mitchell
    Oct 25, 2009
    738
    207
    Hi all,
    How would I go about designing a voltage controlled phase shift?
    I know that you could use an active amplifier (op amp configuration) and use a FET as a voltage controlled resistor with a capacitor to adjust the cut off frequency but thats very ugly. For one, different FETs have different characteristics so I dont want to be designing a circuit specific to a single FET.
    Any ideas?
    All the best,
    Robin
  2. Kermit2
    Feb 5, 2010
    3,854
    968
    ? use an op amp in a capacitor multiplying mode and vary the gain(capacitance) of it with a digital pot in the place of a gain resistor. the shift would be limited in range though. ?
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    what frequency range?
  4. Robin Mitchell
    Oct 25, 2009
    738
    207
    Well the range would be the human hearing so about 16Hz to 20kHz
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    search "flanger" a phase shift sound effect for guitars.
  6. crutschow
    Mar 14, 2008
    13,521
    3,388
    Robin Mitchell likes this.
  7. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,709
    1,301
    Can you clarify your requirement? A phase shift of xx degrees across all frequencies, or a time shift of xx milliseconds? The two are very different. If you want a variable time delay, which equates to a different phase shift at each frequency, then a bucket brigade or charge coupled device will do it in the analog domain, or an A/D-shift register-D/A in the digital domain. A voltage-variable delay line over 11 octaves would be tough.
    ak
  8. alfacliff
    Dec 13, 2013
    2,449
    428
    another way would be a synchro control transformer, an odd thing looks like a motor, with two stator windings 90 degrees apart and a single rotor winding. commonly used to provide the x and y deflection for radar indicators.
  9. Veracohr
    Jan 3, 2011
    559
    77
