Voltage Controlled Oscillator now hooked to a second stage - opinions sought!
Discussion in 'Wireless & RF Design' started by Spottymaldoon, Mar 21, 2016.
  1. Spottymaldoon
    Dec 4, 2015
    53
    People here were kind enough to help me track down a 70-135 MHz VCO problem recently - I have now incorporated all those suggestions and have coupled this to a second stage that uses a low power (1W) RF FET PD5700. The VCO puts out around 100mV and I am hoping to boost this to give 1/4W or so for final delivery of 5W in the 3rd stage (not yet designed).
    Note the FET sits on that big footprint on the right and under-side of the board - I am trying to allow space for some heat dissipation in case I can increase the wattage - output is controlled through gate bias voltage.
    I have not yet calculated the final source resistor value for matching here and on the output I am using two rather large old-style trim caps.
    Here is the schematic and the proposed board - all comments welcome and appreciated !
  2. KL7AJ
    Nov 4, 2008
    2,047
    295
    What happened to your varactor diode?
  3. Spottymaldoon
    Dec 4, 2015
    53
    Still there - now shown as a 5-25pF capacitor
  4. KL7AJ
    Nov 4, 2008
    2,047
    295
    Ahh...just wondering. Well, anyway, I think your circuit is sound. You want to minimize loading on the oscillator by subsequent stages. If this turns out to be a problem, you can add a source follower between the two existing transistors.
    Eric
  5. Spottymaldoon
    Dec 4, 2015
    53
    Thanks for taking a look, Eric. I had hoped to have as few transistors as possible but the VCO feature meant that the oscillator stage has to go really easy, voltage wise, on the varactor (at least that's what I found when I tried it) - am I being realistic here to expect 5W output in three stages?
    Regards
    Dick
  6. Spottymaldoon
    Dec 4, 2015
    53
    Following Eric's good advice, and not wanting to make yet another defunct board, I've added in a buffer stage to the previous circuit. I haven't done the matching calculations for the coupling capacitors yet but is my general idea OK? See below please: buffer added.jpg
  7. SLK001
    Nov 29, 2011
    852
    243
    I would move C26 inside of C3 at the output. Also, if you are going to have this board commercially fabricated, you should put in a lot more vias to connect TOP GROUND and BOT GROUND. I only see three vias. I should see up to 50. I also would NOT put thermal reliefs anywhere on the board.
  8. MikeLogix
    Mar 1, 2016
    One comment on your emitter follower. The idea of using the buffer is that it presents a high impedance to the source driver. Your biasing arrangement for the base, using 680Ω/100Ω presents a low Z to the proceeding source. My only suggestion would be to scale up the divider.
  9. Spottymaldoon
    Dec 4, 2015
    53
    Thank you for your advice.
    SLK 001 I take your point regarding the need for multiple inter-plane grounding points - as I make my own circuit boards 50 is rather a large number of vias but, thanks, I have added a lot more. Can you please mention your reasoning for the re-positioning of that blocking capacitor? According to my simple logic it should make no difference either way.
    MikeLogix Thank you for your incontrovertible point, I'd totally bungled it there!
    Back to the soldering iron!
    Dick
  10. SLK001
    Nov 29, 2011
    852
    243
    The variable cap is part of your output match. C3 is your output coupling cap. It should be the at the output. With it in the position of your schematic, the match inductor is the result of XL14 - XC3 at the frequency. The change will be small, but it will still change. With C3 outside of the match, the match won't be affected by it.
  11. Spottymaldoon
    Dec 4, 2015
    53
    Thanks SLK001 - I figured that must be the reasoning.
    Dick
  12. KL7AJ
    Nov 4, 2008
    2,047
    295
    This is why I suggested an FET source follower. The BJT may be fine, though, with the right biasing impedance....the proof is in the pudding. :)
  13. KL7AJ
    Nov 4, 2008
    2,047
    295
    Someone once said the Platypus was an animal designed by a committee. I hope this circuit doesn't end up a platypus. :)
  14. Spottymaldoon
    Dec 4, 2015
    53
    This platypus is a tiresome beast.
    I find the overall circuit has an acceptable gain but at the cost of producing an unacceptable waveform. At the risk of being boring here is the latest schematic, layout and final board: 25MAR16 circuit.jpg art & board.jpg art & board2.jpg
    After adjusting the four capacitors and running at 125MHz I get this waveform at the output of the oscillator: pre buffer.jpg
    and after the buffer I get this:
    this form is not much changed through the final FET stage and there is good gain with the RF voltmeter showing 3V+
    Any ideas to tame this brute?
  15. Spottymaldoon
    Dec 4, 2015
    53
    Woops (how embarrassing) I missed C20 which decouples the oscillator load from the power supply - let me fix that and report any improvement before anybody wastes their time.
  16. SLK001
    Nov 29, 2011
    852
    243
    As I said in your last thread, your layout is hideous. Your GROUND signal is relatively high impedance EVERYWHERE! From the voltage regulator, GROUND is a small "island" with only one connection to the bottom GROUND signal. For each component that is connected to GROUND, trace out its path back to true GROUND and you will see what I mean. I'm surprised that your signal looks as clean as it does, but I think that your scope can't really "see" the actual signal.
    Also, when you post the bottom side, post it as read from the top. The text will be reversed, but most of us can read a board layout like that. It is also easier to get a feel of the TOP-BOTTOM flow.
  17. Spottymaldoon
    Dec 4, 2015
    53
    Decoupling capacitor fixed. Waveform is improved but still appears unstable:
    This is at the output - my scope is only rated for 100MHz and this is 125MHz but the RF voltage meter shows 1.1V here.
    Can I hope for better stability?
  18. Spottymaldoon
    Dec 4, 2015
    53
    [​IMG] SLK001 said: "As I said in your last thread, your layout is hideous. Your GROUND signal is relatively high impedance EVERYWHERE! From the voltage regulator, GROUND is a small "island" with only one connection to the bottom GROUND signal."
    Appreciate your input. Maybe I can try whacking in a few more vias at strategic spots - or is this board a basket case in your opinion?
    Dick
  19. Spottymaldoon
    Dec 4, 2015
    53
    SLK001 - sounds as if you do a lot of this; in an arrangement like this, is the main source of ground impedance the actual vias themselves or is it more the horizontal distance between desired ground-points? From what I remember of waveguides in physics at school, this frequency is too low and the geometry too small for significant standing wave effect - i.e. ~3m wavelength.
    Dick
  20. SLK001
    Nov 29, 2011
    852
    243
    It is both. Just estimate the inductance between the ground points. For instance, a via has approx 1.5~2 nH by itself. That's why I suggested more vias. They would be in parallel, so the effective inductance would be reduced by 1/N, where N is the number of vias.
    Here is a suggestion to try to salvage your current board. The red lines are 16 gauge solid copper wires soldered from ground to ground. The red rectangles are additional 1000pF bypass caps.
