Voltage Controlled Capacitor
lkgan
Joined Dec 18, 2009
117
Currently I need a voltage controlled capacitor that has value between 1nF to 2μF. Besides connecting the varactor (which has low capacitance value ~ pF range) in parallel, anyone has any idea on how to achieve the mentioned values using a different approach? Appreciate if you can share useful information. Thanks
Regards,
lkgan
beenthere
Joined Apr 20, 2004
15,819
My guess would be a switching setup where you can switch in several decades of fixed capacitors. You might need to use mechanical switches. Perhaps a couple of thumbwheel switches to select the desired capacitance.
This would work for a lab capacitance box, but not for much else.
lkgan
Joined Dec 18, 2009
117
Well, I actually plan to control the capacitance value using a microcontroller for automation purposes, hence need to use voltage to control it. Any suggestions for it?
tom66
Joined May 9, 2009
2,595
Use caps connected to a microcontroller pin. Make the pin hi-Z (tristated) to remove the capacitance; set the output low to use the capacitance.
bertus
Joined Apr 5, 2008
22,276
What voltage is expected on the "variable" capacitor?
What frequency is the voltage accross the "variable" capacitor?
Bertus
Adjuster
Joined Dec 26, 2010
2,148
What sort of Q or loss angle do you need, and over what frequency range? If you are going to use the approach of switching capacitors using analogue switches, micro-controller pins etc, the switch "on" resistance may have a big effect.
For instance, the CD4066 might have 80 ohms on resistance, but the reactance of 1μF at 1kHz is only 159 ohms - not very high Q!
In addition, the current carried by the capacitors must be within the ratings of any switches you use.
Ron H
Joined Apr 14, 2005
7,063
Regards,
lkgan
What are you really trying to do, i.e., why do you need a voltage controlled capacitance?
We frequently get questions wherein the OP has already decided on a general solution to a problem but needs a piece of "unobtanium" to complete the design. There may be another approach to solving your problem that does not require a part that you cannot get.
Having said that, there are probably ways to make voltage-controlled high capacitances, but they probably involve analog multipliers, which are expensive and require a high degree of circuit design capability.
lkgan
Joined Dec 18, 2009
117
Thanks everyone for giving possible solutions. I am actually trying to vary the variable capacitor for filtering purposes. Here comes my answer for others.
Could you use ganged caps switched in and out with a 4066 analog switch?
It is possible to use analog switch to choose different capacitors, but I am afraid that the switching might introduce noise. This might also adds more complexity to the whole design to be bulky.
Can you please explain more on this concept (probably with a diagram for better illustration), don't really get the idea.
Bertus
The expected voltage should be less than 16V.
The frequency is in kHz to MHz range.
Thanks for mentioning the possible problems for using analog switches. Generally the Q doesn't really matter for now, since I am not sure how the Q will affect the overall performance.
You can also research on opamp based "Capacitance multiplier".
An image from Wiki:
Thanks for giving a new solution that I have never thought of. I think the op-amp introduces extra noise to my design, might not be able to use it and it's quite expensive to have this design.
Is the analog multiplier you mentioned same as the one suggested by eblc1388 using op-amp approach?
bertus
Joined Apr 5, 2008
22,276
Can you post a schematic of the intended circuit?
16 Volts is to high for analog switched.
Is the capacitor grounded?
If so, than you could probably use mosfets for the switching.
Bertus
lkgan
Joined Dec 18, 2009
117
Hi Bertus,
Sorry to say that I actually haven't design the schematic, it's just a concept in my mind, I am still open for ideas. It's for filtering purposes. MOSFET switching approach is a choice but I will need to check whether it will contribute extra noise to my system.
Ron H
Joined Apr 14, 2005
7,063
No. Eblc1388's circuit does not have voltage control capabilities. Perhaps he was think that you could replace the capacitor with a varicap, but it would be a big stretch to get from the capacitance of a varicap to the range you want.
Also, varicaps are two-terminal devices, so their capacitance is modulated by the signal. This is not a good thing if you are working with high-level signals.
lkgan
Joined Dec 18, 2009
117
Well, apologize that I did not justify clearly before this. The range I mentioned can be split into few particular small ranges. Perhaps 0.1nF to 10nF for a varicap. And another one would be 1μF to 2μF, something like that. Of course it will be ridiculous for me to design a varicap that works 1nF to 2μF :D
Ron H
Joined Apr 14, 2005
7,063
What order filter do you want? AFAIK, it is easier to make a voltage controlled resistor than it is a voltage controlled capacitor.
Another possibility is switched-capacitor filters, but I don't think you can get them that will work at MHz signal frequencies.
eblc1388
Joined Nov 28, 2008
1,542
Actually no.
I was thinking about the possibility of using large value capacitor and changing digital pot taps to get what the OP wants.
Ron H
Joined Apr 14, 2005
7,063
Lkgan, If you can be happy with a tunable filter that will not work past 100kHz, have a look at LMF100. You probably won't find a simpler way to tune a filter. Tuning is done by varying the clock frequency.
