I am trying to make a voltage clamp for an automotive boost sensor.
the sensor on the vehicle has a range of approx 0.8v at atmosphere and 3.0v+ under boost. i wish to clamp it at approx 2.5v - 2.6v,
I built a silicon chip Fuel cut defender ( http://www.siliconchip.com.au/cms/A_108397/article.html ) but if any voltage of less than 1.4v is on the input the output stays at 1.4v and i do not understand why. above 1.4v the input and output are approx the same until the clamping voltage, as expected
an alternative circuit or other suggestion would be much appreciated.
Thanks.
Thanks.
