voltage buffer using TL082CP
Discussion in 'General Electronics Chat' started by legolas11, Feb 26, 2013.
  1. legolas11
    Feb 26, 2013
    55
    Hi all,
    I am trying to design a simple voltage follower in breadboard using TL082cp opamp and the circuit is attached. However i am getting very noisy output even though the simulator worked fine.
    I have connected everything as in the picture and connected the ground probe of osciloscope to the negative supply. Is there anything that i did wrong here?? is it necessery to use a ground connection here.
    Thnak You
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    TL082 requires a dual supply. If you are going to operate it from a single 10V supply, you will have to create a pseudo ground at +5V and reference all signals to this common reference.
    legolas11 likes this.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Also, the TL0xx series opamps can't get within 3v of the negative rail, nor 1.5v of the positive rail. There are many more modern opamps available which are RRIO (rail-to-rail input & output), in the same prrice range.
    Also, you don't show bypass capacitors across the supply pins. They aren't optional.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    Also, no matter what sort of power supply arrangement you use, the -terminal of the function generator needs to be connected to circuit ground.
  5. DangerousBill
    Jul 21, 2010
    30
    In addition to the issues outlined by others, C3 bothers the hell out of me. Try shorting it.
  6. DangerousBill
    Jul 21, 2010
    30
    I just noticed. Both sides of the signal from the wave generator are floating. There's no hard tie between either signal line and the power supply.
  7. legolas11
    Feb 26, 2013
    55
    Thanks a lot for all the advice. Based on these i have redrawn the circuit. Please tell me if i have anything wrong now.
    So this means all the negative terminal (plus/minus power supply, function generator) should be connected at the same point (ground) .
    And for ground u mean the connection to earth, right???
  8. #12
    Nov 30, 2010
    16,671
    7,314
    "Ground" doesn't actually mean planetary earth, most of the time. It just means "common" in this circuit. Looks good except that there is no reason to drive AC current into a capacitor. Some opamps actually fail when you do that.
  9. legolas11
    Feb 26, 2013
    55
    problem solved...thanks all...
  10. Ron H
    Apr 14, 2005
    7,050
    657
    To emphasize what #12 said, it's not solved until you remove C3. Many op amps will oscillate when cap loaded, and in any case it will screw up the frequency response of your voltage follower.
  11. legolas11
    Feb 26, 2013
    55
    Ya, i removed that too and checked the results with and without it but did not notice any difference.
    Actually the reason to put it there was, i wanted to connect the buffer to an InAmp (ina 129) and so connected a capacitor and resistor (grounded) to the output before leading it to the inamp input terminal. Am i wrong here???
  12. #12
    Nov 30, 2010
    16,671
    7,314
    The input impedance of the next amp will protect the TL082 from pure capacitive loading.
