Hello! I'm new to the forum and pretty new to electronics as well!
So I heard about joule thieves and I am totally fascinated by them! I've been playing around with some simulators and I got them to work in the falstad simulator and also the LTSpice program.
Now I'm trying to change the circuit a bit so that the voltage spikes from the inductor run into a capacitor and it charges up, and then I want to add a zener to control the voltage charged in the capacitor. Normally, the voltage reaches a max of around 200V. (For some reason I can't get this to change, even with different inductor sizes...but in falstad I can easily)
Here is my circuit diagram (w/o zener):
http://www.flickr.com/photos/73128199@N03/8522723460/
And here is the simulation result (w/o zener):
http://www.flickr.com/photos/73128199@N03/8522724358/
Now adding the zener in parallel, reversed with the capacitor should let me control its max V right? So I add in a 100V zener, yet the Vcap doesn't reach 100V for some reason, it won't go past about 15V. This is where I am confused.
http://www.flickr.com/photos/73128199@N03/8522737530/
Now for some reason, this works perfectly fine in the falstad simulator. Here is the same circuit, just with different size inductors and the bottom diode is removed because it isn't needed.
http://www.flickr.com/photos/73128199@N03/8524560566/
And here, the same circuit in falstad with a zener set to 30V...you can see the voltage ramp stops close to 30 as expected. No clue why these things don't work in LTSpice
http://www.flickr.com/photos/73128199@N03/8523448061/
