voltage booster for brushless dc motor
Discussion in 'The Projects Forum' started by fwks, May 20, 2012.
  1. fwks
    May 17, 2012
    12
    hi..im working in a project, voltage booster for BLDC motor.
    can anyone suggest how am i going to do it?
  2. wayneh
    Sep 9, 2010
    12,405
    3,256
    A better question might be, why? What are you trying to do?
  3. fwks
    May 17, 2012
    12
    hi.
    how do i recapture the energy of a BLDC motor during braking?
    any circuit suggestion for it? thank you
  4. R!f@@
    Apr 2, 2009
    8,793
    771
    Just like tht u want us to give u a schematic of regenerative barking ?
  5. fwks
    May 17, 2012
    12
    i want to boost the voltage induced by the BLDC motor during braking for regenerative braking. i not really familiar with electronics. so any helps would help.
  6. cl10Greg
    Jan 28, 2010
    49
    Well a starting point is you would use diodes that would activate when the induced field collapses. From there you could try and boost it to higher levels but I am not sure how efficient it would be. The induced field would collapse pretty fast and you would need a switching application to produce a boost circuit (ie. switching an inductor and cap with a fet at a set frequency). Even with this I am not sure if you could apply that to the battery load to charge the battery.
    You would almost be better off using the induced field to charge a capacitor and then determine a way to use that for charging.
