Voltage Boost
Discussion in 'The Projects Forum' started by jay16, Mar 30, 2012.
  1. jay16
    Mar 30, 2012
    Hi all, I am currently working on powering a 24v DC load, with a 5v Battery. I'm thinking of using a voltage booster circuit to achieve this but can't seem to get at the right circuit diagram. Any kind ideas please?
  2. #12
    Nov 30, 2010
    16,663
    7,308
  3. jay16
    Mar 30, 2012
    Thanks seniormember, for your prompt reply, that was great and snappy, but I couldn't source the 3478 IC locally since time factor is currently a challenge. I was only able to get 741, 555, 7824 ICs. Any clues on going around with these please?
  4. bountyhunter
    Sep 7, 2009
    2,498
    507
    How much current does the 24V rail have to supply? That defines the part you need.
  5. jay16
    Mar 30, 2012
    Its 1.5A sorry I forgot to include that initially
  6. chimera
    Member
    Oct 21, 2010
    122
    yeah.... 1.5A @ 24V ( 36 watts) with a 5V battery is not going to happen... what type of battery is it??
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    Nobody makes a 5V battery. Ni-MH cells are 5V only when their current is far lower than is needed here.
    Maybe it is a 6V 14Ah lead acid battery that could drive a 6V to 24V voltage step-up circuit for 1 hour. Power transistors must have a current of anout 7.2A in the voltage stepup circuit. Maybe a custom-made transformer must be used or a very high current 120V to 30V transformer might work.
  8. bountyhunter
    Sep 7, 2009
    2,498
    507
    The best approach would be to use a push-pull (forward) switcher converter to boost up to 24V.
  9. jay16
    Mar 30, 2012
    The battery actually came with a rechargeable LED touch-light unit and since it is quite cheap for a 30minute exhibition, I felt it could just serve the purpose. It actually dangles between 5V and 5.3V on an AVOmeter and I think could yield up to 6V on full charge. I really would love to try this on the '6V to 24V voltage step-up circuit'. Any further helps on the circuit diagram would perfectly save the day. Thanks a billion Guys!
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, seems that you're just doing some wishful thinking.
    You say your load requires 1.5A @ 24v. Figure ~80% efficiency for the converter (that could be improved with an increase in complexity) so you wind up with a 45 Watt input power requirement.
    At 5v, that's 9 Amperes.
    You've described your 5v power source as being cheap, and being able to power some LEDs for about 1/2 hour. I'd be willing to bet money that your 5v power source would not be able to output 9A @ 5v continuously for more than 10 seconds.
    You're trying to get something for nothing; it doesn't work that way.
    Even if you had an adequate 5v supply, building an efficient 45w 24v supply won't be particularly easy if you have not built one before. You'll need to have an oscilloscope available for troubleshooting, too.
    You will likely be much better off to simply use a pair of 12v SLA batteries wired in series.
  11. bountyhunter
    Sep 7, 2009
    2,498
    507
    Or get three more of the cheap 6V batteries he already has.
