Voltage Attenuation
Discussion in 'The Projects Forum' started by marims, Jan 19, 2011.
  1. marims
    Jan 27, 2008
    15
    Hi
    I am working on a signal generator project,it generates a square wave of 1 MHZ, 5Volts outputs.For a application I need to attenuate the amplitude to as low as 600mV,I welcome your suggestion.
    Note: I do not wish to use voltage divider circuit.
    Thank u
    Marims
  2. KMoffett
    Dec 19, 2007
    2,586
    234
    What load will you be driving with the 600mV?
    Ken
  3. Gundalf
    Jun 22, 2010
    13
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
