Voltage and current sources?
Discussion in 'General Electronics Chat' started by Haripriyan, Oct 29, 2007.
  1. Haripriyan
    Oct 29, 2007
    In theorems like thevenin, it is said that a Voltage source can be replaced by a short circuit and a urrent source is replaced by an open circuit.
    Why is this so?....
    I feel that i know that partly....but couldnot explain that...
    So could any one of you can help me by giving the reason???
  2. mozikluv
    Jan 22, 2004
    1,437
  3. mozikluv
    Jan 22, 2004
    1,437
  4. cumesoftware
    Apr 27, 2007
    1,330
    11
    Because an ideal voltage source has no thevelin resistance (associated series resistance), while an ideal current source has infinite thevelin resistance. The last part is true, because an aproximation to a current source would be an almost infinite voltage ideal voltage source in series with an almost infinite resistance. Such resistance would effectively limit the current by itself. It is so big, that the load has almost no effect.
  5. chesart1
    Jan 23, 2006
    269
    If a power supply is off, the voltage across the output terminals is zero. The theory is that if the voltage across two terminals is zero, than no resistance exists between those two terminals. Hence the power supply would look like a short circuit when it's output is zero volts.
    If a current supply is off, than the current across the output terminals is zero. The theory is that any two terminals that conduct zero current must have an infinite resistance. Hence, the current source would look like an open circuit when it's output is zero amps.
