hello all, This is my first time posting in here, I tried using the search bar to see if there was an answer to a similar question but I did not find one.
I just finished one problem where I had an ideal diode connected to a square wave with a peak to peak at 6 volts. Then the diode splits to an out put Vo and also down to a 100 ohm resister which is grounded.
The question asked for both the peak and avg output voltage and also the peak and average current running through the diode, then finally asks what the maximum reverse voltage across the diode can be.
This was a simple task where I answered all the questions in short order, however the next question asked me to repeat the process if the square wave now has an average of 2 V but keeps the same peak to peak. I assume the max values stay the same but I am not sure at all how to change their averages. I have looked on google and not found a problem dealing with this kind of thing...any help would be appreciated, thank you.
