Voltage and conductor contact
Discussion in 'General Electronics Chat' started by nDever, Sep 3, 2011.
  1. nDever
    Thread Starter Active Member
    Jan 13, 2011
    154
    Hey guys,
    I have a question regarding a qualitative property of electricity.
    I understand that if a certain conductor, for example a battery cathode, has x voltage with respect to ground, and another conductor, for example a piece of copper wire, is connected to it (soldered, physically connected, etc.), then that wire has the same voltage as the battery cathode.
    What is happening at the molecular level? Are the electrons from the cathode and the wire being shared?
  2. iONic
    Nov 16, 2007
    1,422
    68
    What we thought was solid, unmovable, is now liquid and fluid! ?
  3. #12
    Nov 30, 2010
    16,673
    7,320
    Once the contact is made, electrons can flow to your meter by sneaking in between the atoms. In a DC (battery circuit) they only flow in one direction. Attaching the meter allows some electron movement. The meter is designed to show the voltage by measuring how many electrons flow per second through the internal resistance of the meter.
