Voltage Amplifier Design
Discussion in 'Homework Help' started by fastcharlie, Nov 11, 2014.
  1. fastcharlie
    Mar 25, 2010
    I am having difficulties on how to start the design.
    Could you please guide me through this?
      File size:
      59.9 KB
      74
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Goto DigiKey.com. Do a parametric search for OpAmps that might do it. If not, what external circuitry might you have to add?
  3. upopads2
    Member
    Sep 20, 2014
    52
    Take a look at the topology and Bill of materials on this website:
    http://www.instructables.com/id/Op-amp-based-PWM-genarator/
    You want your harmonic distortion in this example to be the pulse width modulation out (PWM he has) to have that harmonic behavior your teacher describes. Take a look at the BOM study the op amp data sheet he describes and I did not help you.
  4. fastcharlie
    Mar 25, 2010
    I want to use two bjt 2N3904 as this is what I been taught in my class.
  5. Jony130
    Feb 17, 2009
    3,990
    1,115
    With only two BJT ?? Impossible, but you could try.
  6. fastcharlie
    Mar 25, 2010
    Well do you think four will do?
  7. Jony130
    Feb 17, 2009
    3,990
    1,115
